Old 05-10-2005, 10:50 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Mobil One Synthetic ATF
Saturday I'm going to do my first transmission fluid and filter change on my 2002 Intrigue at 42,000 miles. I plan on using Mobile One synthetic ATF unless anyone here has had problems with it.
I've used it on my automatic Ford Focus 3 times, and now have 136,000 miles on it, with no problems.
Anyone had any experience with the 4T65-E and Mobile One ATF? Good? Bad? Thanks!
Old 05-11-2005, 03:12 PM
TLgunner TLgunner is offline
Soon after I bought our '01 Intrigue, I changed the ATF to RedLine D4 with no problems. At about 45K miles, I replaced the transmission pan with one with a drain plug and cooling fins, cleaned the magnet and replaced the filter. I refilled the trans with Mobil 1 ATF and the car now has 52K miles on it with no problems to report.
M1 ATF is as good as any other synthetic ATF and is much more readily available and the price is reasonable. It's a good ATF to use in a 4T65E.
I should clarify that the only problem we've had with our transmission is the hard shifting problem some have reported. We had the PCS solenoid replaced under warranty and the shifting has been smooth as glass. This was, of course, unrelated to the ATF.
Old 05-20-2005, 10:16 PM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
TL gunner.
Where did you get the tranny pan and how much did it cost?
Old 05-21-2005, 10:22 AM
Re: Mobil One Synthetic ATF
It's a MotorSports Performance pan:
Check out their website:
http://www.motorsportsperformance.com/index.html
Old 05-23-2005, 09:03 AM
02Olds's Avatar
02Olds 02Olds is offline
when you changed the tranny fluid,did you just drop the pan or did you drain the torque converter too?
Old 05-23-2005, 07:58 PM
kmohr3's Avatar
I just dropped the pan and filter. I let it sit for awhile, and was kind of surprised that I got 7.4 quarts out of it. As far as I know there is no torque converter drain.
Old 05-24-2005, 03:05 PM
02Olds's Avatar
what is the total fluid capacity?
