Old 05-10-2005, 09:57 PM
Juggalo Juggalo is offline
Unhappy Blown tranny! *Pics* Car 4 sale!!
Well as you can see the tranny is defently gone.. i have put more money into this car then i want to think about.. its a '99 Gs 5 speed.. i have a intake.. header..exhaust and blitz kit on it.. only 70k miles.. new tires and battery if anyone is interested in buying a car w/ a blown tranny email me and we can work something out.. [email protected]
Old 05-11-2005, 01:33 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Blown tranny?
smoke....oil....need some more info here....does your motor start? if not, it's not a blown tranny get under your car and look. if there's a hole in your block with a rod sitting there saying "HELLO!" then you need more than a tranny. if your motor starts, and you push the clutch in, are you able to select any gears? as for a new tranny, hell auto zone carrys our trannys now. my tranny costs $1200 from them i believe, w/ a warranty. yours should be cheaper cause it's a GS. or try junkyards. but don't buy a tranny unless you know for a fact your tranny blew.
Old 05-11-2005, 07:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Blown tranny?
I've blown more trannys than I could count, and never saw any smoke. Just not enough heat in the tranny to make smoke.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-11-2005, 10:40 PM
macder macder is offline
Send a message via MSN to macder
Re: Blown tranny?
I've blown 2 tranny's and also did not see any smoke, seems like you have a more major issue on your hands.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 05-12-2005, 12:01 AM
Re: Blown tranny?
anyone have any trannys for sale? if you do email me @ [email protected] .. thanks
Old 05-12-2005, 01:34 PM
AF - Advisor
Re: Blown tranny?
I suppose a hole in the tranny could dump some oil on the downpipe and make smoke... Is there a hole in your tranny?
Kevin Jewer
Old 05-12-2005, 05:03 PM
Re: Blown tranny?
Try calling some local Japanesse used parts place. From my experience they ussualy offer good prices and most of the time are negotiable.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 05-12-2005, 08:47 PM
ned032002's Avatar
ned032002 ned032002 is offline
It just sounds like some gear oil got on the exhaust and that is what caused the smoke because I also have never heard of smoke from a blown tranny, but hey it could happen.
Old 05-12-2005, 09:43 PM
roach2k2's Avatar
roach2k2 roach2k2 is offline
Send a message via AIM to roach2k2
Re: Blown tranny?
the only kind of smoke i ever heard of from a blown tranny is the fluid drippin onto the manifold or a hot part, Thats the only time i seen a blown tranny smoke and thats cause there was a hole blown through it from a gear or a bolt flying off and through the case. Usually when you blow a tranny you just wont move lol.
91 Eagle Talon ESI
-new tires and rims
- rebuilt tranny
- rebuilt ECU
-LOOKIN FOR A TURBO AWD DSM! HELP ME!
Old 05-13-2005, 06:55 PM
AF - Advisor
Re: Blown tranny?
Thats a nice hole there Certainly explains it all. Most likely knocked a tooth or two off a gear, it got between the diff and the case, and got kicked through for 3 points.
Kevin Jewer
Old 05-14-2005, 10:22 AM
Re: Blown tranny?
yea its a nice hole lol .. to bad i don't have the money to fix it!
Old 05-14-2005, 11:06 PM
AF - Advisor
Re: Blown tranny?
Who does...
Kevin Jewer
Old 05-15-2005, 01:35 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: Blown tranny?
Welcome to the world of DSM's. I need a motor.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
