Old 05-10-2005, 08:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Overheating or bigger problems??
alright, i just re-built the motor and have about 100 miles on it and now today it started steaming and it sounded like the coolant inside the water neck was boiling. steam was coming out around the cap area (might be the upper radiator hose too). the weird thing is though is that it didn't pull out any coolant from the resirvor. the engine temp also started to climb too. my question is, what would cause this? a stuck closed/open thermostat or what?? i also just blew out the radiator too so it's not a plugged radiator.
95 Talon TSI AWD
97 Eclipse GST
Old 05-11-2005, 01:39 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Overheating or bigger problems??
thermostat is probably stuck...do this. start the car, let it reach normal operating temp, then grab a hold of the upper radiator hose. is it cold? if so, the thermostat is stuck. get a new one. could be a faulty water pump too.
Old 05-11-2005, 01:50 AM
joemathews's Avatar
joemathews joemathews is offline
What is steaming? You can take out your thermostat and put it in a pot of water on the stove. Heat the water until it boils. If the thermostat opens properly, it's working alright. It should be fully opened by the time the water boils. If it remains closed, it was the problem. Replacing it is cheap and easy.
Other things to check are cooling fans, water pump, head gasket, and a few more things. Try the thermostat first, though. It is probably the most common problem, and one of the most easily fixed. Don't be like me and pull the timing belt off to check the water pump to find out that it is okay.
1996 Eagle Talon
Old 05-11-2005, 10:10 AM
well the motor was just re-built and the water pump was working on my other motor so i don't think that's the problem, also it ran fine and the temp was good the past 100 miles that i've driven it and it just did this today. i went to add coolant and found that my radiator cap was loose so i added more coolant and put the cap on tight, we'll see if that was the cause of my problem. otherwise i'm going to do a pressure check and see if i have any leaks.
95 Talon TSI AWD
97 Eclipse GST
Old 05-11-2005, 12:26 PM
alright so after adding coolant and tightening the radiator cap, i drove it home (about a mile) and it was already at normal operating temp. half way there. i pulled into my driveway and popped the hood to check the coolant level and then my serpentine belt started squealing. i got in the car to shut it off and the temp was way up there, not hot but on the way. what would cause it to heat up so quickly? the upper radiator hose is the same temp as the coolant. anyone have any suggestions??
95 Talon TSI AWD
97 Eclipse GST
Old 05-11-2005, 12:50 PM
could be a bad head gasket or bad water pump. i read somewhere that if you have bubbles through the system, that could cause overheating problems also. you could try draining the radiator fluid and filling it up again. make sure you are using a 50/50 mix of radiator fluid and distilled water. you can buy the stuff already pre-mixed.
Old 05-11-2005, 01:26 PM
it's a brand new head gasket and new coolant throughout the whole system. it's also an exactly even 50/50 mix.
95 Talon TSI AWD
97 Eclipse GST
Old 08-08-2005, 02:02 PM
97gst-04ralliart 97gst-04ralliart is offline
I just got a 97 gst. It was overheating so I replace the thermastat, the water pump, the radiator cap, and I check all the hoses and the radiator. But it still overheated. So I was sure it was the head. I took the head to a machine shop and resurfaced it. I also replace the head gasket but it still overheated. I have no clue what it could be. Is there anything I missed?
Old 08-08-2005, 02:51 PM
damn this thread is a couple months old....umm, are you filling the radiator with a 50/50 mix? also be sure there are no air bubbles...after filling it, you have to start the car and let it idle for a little bit. after the engine cools, pop the radiator cap off and fill it again because it will be low. other than that i don't see why it's overheating unless there is something wrong with your temp gauge. you said you replaced just about everything else...
Old 08-08-2005, 10:00 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
it sounds to me that you have a warped head
you better yank that thing and check it before
anything worse happens
Old 08-08-2005, 10:49 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Re: Overheating or bigger problems??
hmm...
Ok well have you checked to see if your burning any? If you are then if your head gasket is good then maybe it's the heater core, usually there will be the smell of antifreeze inside the car when you have the heater on and that smell is sweet... not cool but like Koolaid (it smells delicious) . Where is the steam coming from? I think you said that it was coming from the loose radiator cap...have you fixed this problem by tightening it or did it still steam around it? Keep us informed.
Old 08-09-2005, 12:24 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
I read through your post and i don't remember reading whether or not you said you replaced the radiator cap. If the steam's coming out from there, then chances are it's no good. On top of that, if it's not pressurizing the cooling system, the faulty cap will allow the coolant to boil and run hot regardless if the thermo is open or not. Check the simple things first, and don't mind me if you said you already replaced it, though i don't believe it was mentioned.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 08-09-2005, 08:54 PM
ned032002's Avatar
Originally Posted by tsipsi20
I read through your post and i don't remember reading whether or not you said you replaced the radiator cap... don't mind me if you said you already replaced it, though i don't believe it was mentioned.
I recon this I didn't read that you had replaced it as well, sorry if you did though .
Old 08-09-2005, 08:57 PM
ned032002's Avatar
So if this thread is so old then maybe the problem is already fixed cause hes really not responding at all to any of the previous posts...o well maybe we have served some purpose with our words.
Old 08-10-2005, 12:39 AM
Let us be an example for others
MOD LIST:
