Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 05-10-2005, 07:08 PM
bubbass69 bubbass69 is offline
installing a blower motor for a 2001 sunfire
mine is blown any insight on how involved install may be will be greatly appreciated
Old 05-11-2005, 06:51 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: installing a blower motor for a 2001 sunfire
Not to hard to do.
It's located under and behind the glove box on the passenger side. Remove the plastic panel and you should see the motor assembly, 3 screws hold it
in place. While replacing the unit, it's real easy to work on if you remove the passenger seat.
Before replacing the unit, is the motor completely toasted, or does it only work on high-speed position only? If it does run on high speed but not the 2 slower positions, it's the blower resistor unit which is also located in the blower motor housing.
