Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 05-10-2005, 05:34 PM
flip888 flip888 is offline
Homemade Turboback Exhauist
I was just wondering how hard it would be for me to make my own turboback for a 92' eclipse GSX if i already have all the piping and a welder.
Old 05-10-2005, 05:41 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Homemade Turboback Exhauist
do you have a pipe bender?? if you do, and know how to use it, it should be very easy, and cheap.
Old 05-11-2005, 03:30 AM
I dont have a pipe bender but the shop that i got the pipeing from sayd they would give me some pre-bent pipes that they have laying around that i thought i could weld to the pipes i already have.
And i wanted to ask if i could cut the pipes at angles and then weld them together. For example if i wanted a 90 dagree bend, could i cut both the pipes at 45 dagree angles and then weld them to eachother?
How would that compair to a mandral bent exhaust?
Old 05-11-2005, 04:57 AM
astroracer's Avatar
astroracer astroracer is offline
Re: Re: Homemade Turboback Exhauist
Try this with a garden hose... Lay the hose out with a series of nice smooth bends, something like you would see with a mandrel bent exhaust system... Turn on the water and note what kind of flow you get.
Now, re-do your layout with a series of 90* bends similar to what you are suggesting with your cut and welded bends. Turn on the water and note what kind of flow you get.
Give us a report back after you do this...
Old 05-11-2005, 06:05 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
What kind of welder? I weld exhaust systems all the time, whether its from scratch, or from a kit, they are all the same and easy. But dont try and balogne cut it to avoid bends.
-Mike
