Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-10-2005, 04:06 PM
nschoma nschoma is offline
95 tbird passing gear
I have a 95 tbird 4.6 that I replaced the motor at only 117k mi. After doing so, now the tranny is no longer working properly. When stomping on the pedal, the passing gear does not kick in automatically. I must manually change the gear to get the car to accelerate. BTW, changed the tranny fluid and filter prior to this.
Old 05-10-2005, 05:00 PM
Donald91tbird Donald91tbird is offline
Send a message via AIM to Donald91tbird Send a message via Yahoo to Donald91tbird
Re: 95 tbird passing gear
That is really weird...It revs then you have to manually change?
Old 05-10-2005, 11:56 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
It sounds like an electrical fault. Do you have a check engine light? It could also be your Throttle Position Sensor that is acting up, thus not allowing the transmission to downshift. Get that sensor checked out and see what goes.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-11-2005, 08:11 AM
It doesn't rev, if anything, the rpms drop a little.
Old 05-11-2005, 09:54 PM
that sounds like your torque converter clutch solenoid is acting up; if it sticks, it can cause the problem you're having. I'd suggest going to a transmission shop and have them see if there are any fault codes stored and have them look at the data stream to see if there are any irregularities.
