Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-10-2005, 11:00 AM
Mama's T-Bird Mama's T-Bird is offline
Send a message via Yahoo to Mama's T-Bird
Unhappy A/C cuts out
First, thanks to all that have posted and all the education I've received. Problem: 1991 T-Bird 114,000 mi. New A/C installed Jul-1998 (used R134a), Oct-1998, had wide-open-throttle relay replaced cause A/C was intermittant, Sept.-2002 had pressure switch replaced cause A/C was not working. Now under heavy acceleration A/C stops being cold (blower still works). In idle in driveway, can rev-up as much as I want and A/C works O.K. A/C is pretty cold for a 14-year-old Bird. Any ideas ???----Thanks in advance
Old 05-10-2005, 11:18 AM
Donald91tbird Donald91tbird is offline
Send a message via AIM to Donald91tbird Send a message via Yahoo to Donald91tbird
Re: A/C cuts out
I have the same model and year... my car always is slightly cool on VENT, and with Max A/C blasted its just blowing warms/slightly cool air.
I don't know where to start with A/C's but I'm guessing it could use frion? or a recharge kit? Isn't refridgerant for our car expensive now?
A Quick Fix for now... What I have on my car is a 12 Volt FAN clipped on the side of my glove box. It's extremely affective at night time and helps during the day. Only cost's about 10$ at walmart. hahaa It helps! Summer time is here.
And on that note you might want to get a Radiator flush if your living in an hot area before temperatures rise. Since the main cause of breakdowns in the summer is obviously overheating. =P
Old 05-10-2005, 05:19 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: A/C cuts out
During high engine speeds and acceleration the compressor clutch is disengaged which shuts off the compressor. It doesn't sound like you have a problem.
Old 09-20-2005, 12:54 PM
VALDI7 VALDI7 is offline
Re: A/C cuts out
HI, I'm have that problem where the a/c cuts out too fast . it's only engaging for about 3 sec. at a time. or is this normal and where is the wide open throttle relay? also i thought it could be the blend door actuator because it seems my heater works but not hot enough just like the a/c , cool but not cool enough. thats for you help.
Old 09-20-2005, 07:30 PM
coondawg6 coondawg6 is offline
1st mamas bird---wot switch cuts off ac at Wide Open Throttle to give all the acceleration possible-only operates in gear--normal operation
2nd valdi7--- you have low pressure problem -get it charged and will not have a problem and seperately flush heater core probably causing not enuff heat
3rd donald91-- yours is either not charged or electrical not working and yes r12 is about $110 a lb and your car takes about 4lb
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 09-20-2005, 11:16 PM
CDJr CDJr is offline
Re: A/C cuts out
Good call, coon!
Old 09-21-2005, 09:50 PM
i try to provide quality customer service to everyone---even if they drive fords lol sorry guys i forget where i am at times--and im too young for oldtimers syndrome
