Old 05-10-2005, 09:16 AM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
Question full carbon body
As probably everyone has seen in the motorsport section there is a killer fully carbon bodied imprezza. my question is do you have to paint the entire body with primer and then a base coat of what ever the colour, if you are going to cover the whole thing in carbon fibre decal. or can it just be put on top of the plastic?
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 05-10-2005, 09:20 AM
Vric's Avatar
Vric Vric is offline
Re: full carbon body
You should use Semi-Gloss black base coat
Old 05-10-2005, 09:23 AM
sounds good but i was thinking of the yellow and black decals, will it still be ok to use semi gloss black i should have said the colour in the opening post my bad
Old 05-10-2005, 12:38 PM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Well the thing is, if a very small piece of CF (one square mm for instance) doesn't cover the body, and the body hasn't got more or less the same color, it's very easy to see. That's why you should spray black behind the usual CF. And of course it makes the CF decals look a little bit darker. Behind the yellow black decals you should use something like dark brown I think. Not sure.
Old 05-10-2005, 12:42 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Decals don't stick very well to plastic, and like Bas Carwash said, you need a paint color that will hide any mistakes. I also prefer gloss to semi-gloss, because it is easier to reposition the decal on the surface, but that's just personal preference.
Old 05-10-2005, 04:15 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Re: Re: full carbon body
Water slide decals also work much better on a gloss surfacce, they don't stick well to flat and semi gloss surfaces.
Freakin' Groovin"
Old 05-11-2005, 10:39 AM
thanks for the help guys
