Old 05-09-2005, 10:40 PM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
I need help on memory wire!!!!!!
I install this new deck, and everything works out fine, but then i couldn't find the memory wire. So everytime i start up my car, everything in my deck gets reset. I want to know what color is it?
4TH GEN CIVICS ROCK
Old 05-09-2005, 10:55 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: I need help on memory wire!!!!!!
white and blue
Old 05-10-2005, 04:46 PM
Well i checked my car and it didn't have the memo wire. Only the deck had it. So what, i can't do it then.
4TH GEN CIVICS ROCK
Old 05-10-2005, 05:02 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Just run a fused wire (10amp) from yellow(memory) wire from deck to + side of battery. problem solved. works like a charm. just make sure you fuse it in case of a short or something and fuse it as close to battery as possible.
done this many of times.
GL
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 05-10-2005, 06:29 PM
kris's Avatar
Your car came with it.
Old 05-10-2005, 07:18 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Yeah someone had cut mine short and I had to dig to find it. It's in there just look.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 05-10-2005, 07:34 PM
Scott82 Scott82 is offline
you could actually run it thru the fuse box in an empty slot so that way you don't have to get a fuse holder. Just do like said above, run a wire from the batt. to the fuse panel under the dash and run from the fuse panel to the deck and then you have a new factory look alike memory wire. Just mark where you fuse it so you'll know which one it is if it blows.
Old 05-12-2005, 09:39 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
you could always T-it into the clock memory wire.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-13-2005, 07:44 PM
I was told that the memory wire is color Yellow? So now i'm confused. Is it yellow, or blue with white?
4TH GEN CIVICS ROCK
Old 05-14-2005, 01:12 AM
Jos4DCivic's Avatar
yellow is memory. blue with white line is remote for amp.
91 Hatch SI
Finally painted!!!
Old 05-14-2005, 09:04 AM
I think yellow is the aftermarket color for constant power. I thought white and blue was the stock.
Old 05-14-2005, 10:16 AM
kris's Avatar
Re: Re: I need help on memory wire!!!!!!
yep
