Old 05-09-2005, 09:31 PM
Ironic Ironic is offline
Question How to get codes?
1997 just had fuel pump replaced, have a feeling it may be a loose vapor hose or something related to the work involved in replaceing the pump- I need to know how do I get the codes w/o a scanner? I realize this same thing has been posted probably 50 times already, and it seems the only thing the search engine here can find is that page that says: "page not found"
Old 05-09-2005, 11:15 PM
OverBoardProject OverBoardProject is offline
Banned
Re: How to get codes?
If you live close to an auto zone, take it there. It's a free scan.
If you live in Canada Canadian tire probably offeres the same free service. But I can't promise you that it's free.
Old 05-12-2005, 02:39 AM
S10 Kevin S10 Kevin is offline
You should be able to short pins A&B of the ALDL connector with a paper clip to get your dash light to blink any error codes. You can make a data cable to get full scan information on any PC through the serial port for under $5 with WinADL or other freeware. Google "ALDL" you'll find tons of info. Here's a page that shows the ALDL connector pinout so you know what pins A&B are, and it shows how to build the cable. http://winaldl.joby.se/aldlcable.htm
Good Luck
Old 05-12-2005, 06:21 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Good Luck
He could burn out his ECM doing that... He has a 97 which requires the use of an ODBII scanner. You can only use the paperclip on ODBI..
Old 05-13-2005, 09:46 AM
Fireplug Fireplug is offline
Late 1996 and up all use OBD2 and must use a scan tool to get codes
Old 05-13-2005, 10:14 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: How to get codes?
It's actually late 1995 and up. 1995 was the transition year, the ones with the ECM under the hood need a scan tool. All 1996 and up require a scan tool.
