Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 05-09-2005, 06:57 PM
djbaseball24 djbaseball24 is offline
Send a message via AIM to djbaseball24
Sentra
Whats the difference between a sentra GXE and an SE-R and what mods can I add to the sentra to make it like an SE-r
Old 05-09-2005, 07:12 PM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Re: Sentra
Ask the Sentra guys in the Nissan-Sentra section. But, welcome to AF. May all your wildest dreams come true!
EDIT: Heres the link:
http://www.automotiveforums.com/vbul...play.php?f=207
AF Guidelines. Read and play nicely :
Just Click Here!
Old 05-09-2005, 07:49 PM
TatII TatII is offline
the main difference is the engine. the older boxy B13 sentra's had a single cam 1.6 liter making almost no power, and its very brittle to boost so no one ever bothers to hook those up. the SE-R's for those gen's ran on the SR20DE which was a 2.0 liter that can rev to 7.5K and has 140hp with a limited slip differential int he front. those cars can keep up with B16A powered civics. the engine is also built extremely rugged, and can handle boost really well. even with the high compression pistons, it can handle around 400hp before breaking. or you can just swap in a japanese SR20DET turbo 2.0 engine which can handle over 500hp and its just a turbo, and fuel managment system upgrade away.
the newer B15 sentra's came with a 1.8 liter 4 banger, its still weak, the SE-R's came with the QR25DE which is a 2.5 liter 4 banger that makes great tq but can't rev very high. but it has tons of potential from bolt ons. you can gain up to 30whp from intake, headers, exhuast, and removing the balancing shafts. these things are rated at 175hp and they can run low 15's stock.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 05-09-2005, 09:58 PM
PWRDbyUNCLEbens's Avatar
PWRDbyUNCLEbens PWRDbyUNCLEbens is offline
What year se-r model, and why do you want to know. Just Curious.
1992 Sentra SE-R: Bluebird SR20DET @ 10psi, 3" exhaust, FMIC, Poly-Urethane Motor Mounts, Centerforce (slipping) Clutch, Tein SS coilovers, FSTB, RSTB, 205/50/15 Hankook RS2's
