Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 05-09-2005, 04:04 PM
1phatx 1phatx is offline
Lambo Door Kits
Does anyone know a good place to get a good lambo door kit for my ride?
Old 05-10-2005, 09:15 AM
opinion?
Does anyone have these kits? Who did you buy then from?
Old 05-21-2005, 01:48 PM
2crunk's Avatar
2crunk 2crunk is offline
Re: Lambo Door Kits
Do a yahoo or google search for mustang vertical door kits.
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 05-23-2005, 11:08 PM
eillob's Avatar
eillob eillob is offline
Can't tell you where to get them, but I did see a 2003 with them on at the WFC8 here 2 weeks ago. Looked totally badass. Go for it.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 05-24-2005, 06:28 PM
Re: Lambo Door Kits
Thank you, so far the best place i found them was at a place called redrum customs for $999
Is that a good price?
Old 05-25-2005, 10:48 PM
eillob's Avatar
I don't know. There's a place here in town that does it but its not quite my style so I looked into it. Make sure you check out some of there work before let them start on yours. Make sure your not dealing with some amateur.
Old 08-12-2005, 12:03 PM
CHIVANATOR CHIVANATOR is offline
Send a message via MSN to CHIVANATOR
Re: Lambo Door Kits
you should try Mrbodykit.com They look like they are a good kit and I think they have free shipping also.
Old 08-12-2005, 05:51 PM
eillob's Avatar
Re: Re: Lambo Door Kits
For one this thread is way old, which is a big no no around here. Secondly just about everyone i've ever talked to who purchased from Mr. body kit complained about recieving junk product and being totally ripped off.
Old 08-15-2005, 07:45 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I normally WOULD NOT post in a thread this old...expect someone already brought it bad a life and another post was made in it also after that. That and the fact the only suggestions for lambo doors made were from crap companies and cheapo kits. Casll this post a "for future reference post".....with that said....
Call Decah and talk to Kevin.
Decah, LLC
570-848-2439
www.decah.net
Decah was the orginal company to design and sell the commenly used lambo door kit design so many other companies have ripped off.
They are based in New Jesery, which your profile says you are in.
Also, they make the kit for 99-03 Mustangs, and just in case you are looking for the 88 CRX your profile lists, they make them for that ride too. I also know they have many more apps available they they list on their site. They use good, strong shocks too, unl;ike some cheapo rip off's who's shocks don't hold a door up too well over the long haul.
Kevin is an honest guy and won't screw around with you.
Any problems I've seem with most non-cheapo kits have to do with bad installs, etc...and can be easily corrected. Major problem #1...people over torque the door bolts. Just re-torque em to factory specs, and have someone leaning on the door pushing the door in when you torque em, untill all the door and vdc bolts are torqued. That solves the bigggest issue right there people have with messed up installs.
Decah's a good product. The only other company I'd recommend is GT Factory. They are good also. They use a different design but are not "bolt on" if that matters. You must drill your own bolt pattern or weld them on.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
