Old 05-09-2005, 04:02 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Exclamation Leaking Oil!!
I have noticed that my b20 is leaking oil from right under the distributor.. is there a rubber seal or something that might of broken??
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 05-09-2005, 04:05 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Leaking Oil!!
Dizzy O-ring is cheap to replace.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-09-2005, 04:29 PM
Re: Leaking Oil!!
OK... One question if i take off the dizzy and then put it back on will the engine timing be off ?? or will i have to mess with the timing... cuz for the record i dont know anything about correcting it if the timing is off
°Sä®GëNTö69°
Old 05-09-2005, 05:14 PM
Scott82 Scott82 is offline
Re: Leaking Oil!!
no, there are two forks on the end of the dizzy that line it up for you, you can get the timing 180 degress out if you turn the rotor button, but just remember where abouts your rotor button is pointing when you take the dizzy out and as long as it is pointing to the same point when you put it in then your timing will be fine.
Old 05-09-2005, 08:35 PM
Re: Leaking Oil!!
I Know It Sounds Dumb..the Rotor?? Is That The Thing Inside That Spins Right?? When U Take Off The Dizzy Cap Right??
°Sä®GëNTö69°
Old 05-09-2005, 10:35 PM
Re: Leaking Oil!!
yea
thats it
Old 05-09-2005, 11:58 PM
Hybrid1990crx's Avatar
Re: Leaking Oil!!
you sure its not coming from the cam seal?
Old 05-10-2005, 01:39 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: Leaking Oil!!
Take either a marker like a sharpie or a chisel type punch and make a mark on the top leg (there are 3 legs on distributors) where the leg meets the head. Its the part where the 12mm bolt goes through thats pointing up from your distributor. well anyways, make a mark going the same way that the bolt is going. that way when you put it back on, line the mark up to where it was originally and your timing will be back to where it should be.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-10-2005, 07:08 PM
Re: Leaking Oil!!
Ok... Ill Do That.. Imma Take Off The Dizzy And Check Out Whats Wrong.. Thanks For The Help!!
°Sä®GëNTö69°
