Old 05-09-2005, 02:41 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
16g install kit the same as 14b?
http://www.extremepsi.com/store/cust...cat=336&page=1
will this fit on a 14b turbo, mainly the oil feed/return lines and bolts and washers?
sorry for all the questions lately, i think this is the last one though
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 05-09-2005, 03:09 PM
joemathews's Avatar
joemathews joemathews is offline
Re: 16g install kit the same as 14b?
Yes, that should work with a 14b as well. Don't forget your option to piece together a kit if you want to save some money. You could probably buy a new SS oil feed line from Extreme psi, and find the other parts used, and save yourself $100. But if it's not worth the time, or you're fine with paying $175, go with the new kit
1996 Eagle Talon
Old 05-09-2005, 05:22 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
What I did was peice together my own kit. It is way cheaper then buying a pre-made one. Most of your gasket can be reused, mine were in good condition but I had new ones, so I used the new one. You can buy a J-pipe used of dsmtuners for pritty cheap, and I got my oil feed line for extremepsi.
What you need:
Oil feed line
Oil drain Gasket
J-pipe
What you can reuse:
Manifold to turbo gasket
o2 gasket
Oil drain line (with a little modification)
I think thats about it.
You will have to get new bolts for the oil drain line that bolts to the turbo. The size is a little different.
Hope I didnt forget anything.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 05-09-2005, 10:34 PM
j pipe is taken care of, licp dejon fits, new clamps and what not for 75
95 Eclipse GS-T
Currently:
Soon lol
Old 05-09-2005, 10:41 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
yes, same exhaust and intake housings.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
