Lights dim a bit when using interior window switches
When ever I try to put up or put down all 4 windows at the same time from the master control, the lights dont dim, but when i get to the point where the windows wont go down anymore but i still have the switches down, the lights dim a little bit. Same thing for when i have the windows all the way up and i click all 4 switches to bring the windows up, the lights dim a little bit. Has anyone had this issue???
*- '96 Honda Civic Lx 4 Dr Auto -* *- CAI 2.5in w/aem bypass -* *- Invidia High Performance Cat-Back Exhaust -* *- Suno Hyper Ground System -* *- Front Upper & Rear Upper Strut Bars -* *- Dc Sports Rear Lower Strut Bar -* *- Tom's Lowering Springs 1.5in -* *- 16X7 Konig Blatants w/ 215/45 Falken Azenis -* *- Power Stop Slotted rotors -* *- G-Force 5 Points Harnesses(Only using 4 points) For autocross -* |
Re: Lights dim a bit when using interior window switches
Its really normal. The extra load from the windows going all the way causes a drain on the system.
There is actually what they call an ELD. it supplies the car with the minimum voltage required so the car can operate. Once a load is sensed then the ELD switches the altenator to put out more volts. This can cause a flicker in the lights at nite and thats why the lites dim when you ask the window to move farther than it can go.
Stop asking me about radio codes I cant get them anymore!!! |
It is def normal dont worry.
2004 Ep3 |
