Old 05-09-2005, 11:58 AM
bjboertje's Avatar
bjboertje bjboertje is offline
new setup
i am looking at getting an avalanche 15 and a brutus BX1000D. what is the best way to hook this up (can you wire the sub coils in paralell? a little confused, cause the website says it is dual two ohm coils wired in series).
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-09-2005, 12:02 PM
bjboertje's Avatar
Re: new setup
or maybe should i go with the NX750D? the website also says the sub doesn't need more than 750w.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-09-2005, 12:34 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: new setup
match the RMS of the amp with the RMS of the sub.
and why dont you save to get a better car?
Old 05-09-2005, 01:13 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: new setup
The AVA15 has dual 2ohm VC's... wired in parallel you will recieve a 1ohm load...
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 05-09-2005, 01:39 PM
bjboertje's Avatar
Re: new setup
yeah, i know, but i was confused because the website said they were wired in series and i didn't know if they were fixed that way, or if you could hook it up however you wanted.
my car gets good gas milage, that's why i like it. plus a small hatchback has good acoustics.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-09-2005, 01:45 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: new setup
bx1000d only puts out 600 at 1 ohm. get either a bx1205d or a bx1500d.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 05-09-2005, 01:54 PM
bjboertje's Avatar
Re: new setup
that's not what i have seen. i see that it puts out 1000w rms into 1 ohm.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-09-2005, 02:33 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: new setup
They don't exacly put out rated power anyways, atleast the older ones dont
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 05-09-2005, 02:47 PM
Re: new setup
Its rated at 1000rms, but unless your running a stable 16v your not gunna get that. Expect [email protected] and 750ish at 14.4
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
