Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-09-2005, 11:37 AM
hotep hotep is offline
check engine light!
My check engine light came on so I had the codes checked, read there was a misfire. Replaced plugs and wires, still says misfire. I can feel it when I drive too. I don't know what the problem is. Could it be bad gas (I just replaced the fuel filter). Don't think it's the coil pack case the new plugs are not fried. Any comments are welcome, and thanks in advance.
Old 05-09-2005, 05:46 PM
The Rebel The Rebel is offline
Re: check engine light!
Hey there Bubba Hoteb, (Elvis)
(good movie: Blockbuster or Hollywood Video)
OK hey I see your request, Did you let the gas gage get below the 1/4 mark? This code comes up (misfire) if you let the gas get real low like under 1/4 to almost touchin E....Clear the codes, fill the car with gas, (i know its almost $3.00 a gallon) then make sure the gas cap is on evenly and snug.
Old 05-11-2005, 11:46 PM
zimaad zimaad is offline
Could possibly be a coil pack too. It should tell which cylinder the misfire was in too...this could help your diagnosis.
Old 05-12-2005, 05:23 PM
black96aurora black96aurora is offline
If you have access to a scanner it will list all cyls. and the number of misfires. This will help you identify the cause.
Old 05-29-2005, 09:10 AM
55624096 55624096 is offline
Probably a coil. quick coil check by removing spark plug wire at idle. Each coil runs two cylinders the four cylinders up front will tell the tale. Just remove wire at idle and listen to spark sound when it jumps to ground. hold the wire about 1/4 to 1/2 inch from top of spark plug and you will hear a different spark sound from the bad coil. Then change only the bad coil. Works for me
Old 05-30-2005, 11:03 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
where are you getting your gas rebel? Its only a few cents over $2 here in MD.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 05-31-2005, 09:01 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
A very possible culprit could be clogged / dirty injector(s). A fuel injector purge (60 to 100 $ at a shop) would solve this problem, if that is the case. Clogged fuel injectors are a common problem.
