| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
removing acrylic paint
Hello,
I have interior here which I painted with a self-made mix, I think mix consisted of brown and orange acrylic paints from Tamiya. Mixed paint looked very leather-like, so I brushed it on... When paint dried, I realised my mistake; paintwork was gloss! After that I put on a layer of flat black, but it still was shiny. I now want to remove paint, so I can repaint. Anyone has an idea on how to remove acrylic paint? Maybe with alcohol?
For Tamiya acrylics I usually use water and soap. It wash right off with a bit of brushing with a used toothbrush.
What is understood need not be discussed
Re: removing acrylic paint
If nothing works good enough there is alway owen cleaner or brake fluid.
I'd go with the oven cleaner. Works great for stripping acrylic paints. Just spray on, let it foam up leave for around 30mins - 1hr and just wash off and use a toothbrush to get into the recesses etc..
Oh, and if you like the colour and still want to use it, then put some flat base into your mix next time, this will take the gloss out, and make the mix flat. |
you could brush on some revell airbrush clean, thats if the seats are not glued in as it takes the paint of everything. keep brushing on it will soften paint and then brush off then wash with soap and water let dry repaint easy no soaking quick and easy i even used it to get off humbrol gloss 3 years old.
I've stripped Tamiya acrylics with automotive windshield washing fluid, about 100% ethanol. Works fine.
-Niko
Tamiya acrylics are very easy to strip. Things like oven cleaner and brake fluid are completely unnecissary, they're way overkill. If you soak the part in isopropyl alcohol or glass cleaner, the paint will disolve pretty quickly. Any additional residue is easily removed with an old toothbrush.
PHOTOBUCKET SUCKS |
Anything with alcohol will dissolve acrylic in a hurry, no use going over the top with stronger stuff.
Niclas |
Thanks for answers...
I have tried Druids method (water and soap) but it did not work for me, so I tried Proosens suggestion (alcohol). It rubs of now, but I will leave paint a bit longer in the alcohol to soften the paint more.
Windex work fine too
![]() CarsModeling.com. My Scale Model Cars blog. |
Well, that's just my method that I've been using and if the other method works, try it, maybe i'll try it too because I can't remove Gunze paints using the water and detergent mixture.
Alcohol or ammonia; Windex or similar window cleaner are perfect for removing acrylics. The other chemicals are complete overkill.
My Fotki Album |
I'm now using "Spiritus", which is used for cleaning windows.
It's basically alcohol, and by soaking interior in it I can rub paint right off!
I have a model painted with tamiya spray paint and clear coat, will this method remove the paint from my model?
I would like to refinish it 'cause the first try didn't work very well.
Good luck! Niclas |
