Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-10-2002, 11:34 AM
LX98Civic's Avatar
LX98Civic LX98Civic is offline
Send a message via Yahoo to LX98Civic
Thumbs up My alignment reading! PIC! 3 washers??
There is NOTHING to an alignment. Didn't even have to remove my wheels The mechanic who did the job was cool. He let me watch everything and even get under the car to see how he adjusted the toe. After he did the front camber and then the toe, I asked about the casterand he said it's preset from the factory and nothing you cna do about it
Anyhow, he said the rear was to far off to shim out. Said only up to .75 degrees they can shim out. They offered me a rear camber kit by specialty products for like $220 :o
I told him I will shim it out myself with the bolt and washer trick. He then said to just bring it back and he'll align the toe in the rear again at no charge.
In the front from over 3 degrees negative camber to about 1/2 degree of negative camber. I told him as close to 1/2 a degree is what I am wanting!
What do you guys think? ....3 washers on each bolt?
Here it is:
P~E~A~C~E
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77----------------
--- --- --- -- Sleeper in the middle -- --- --- ---
Old 04-10-2002, 07:08 PM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
whoa shit, more than 3 degrees of camber in the rear. I'd say 4 bolts. I got 3 in mine right now, and I dont think my camber is that bad. Try 4, and get a level and hold it up to the wheels. If its straight, then cool. If not, add/remove as necessary
Old 04-11-2002, 12:32 AM
Rice-Rocketeer Rice-Rocketeer is offline
Shit I have like 5 or 6 on each bolt.
Lookin at my gucci, it's about that time...
Old 04-11-2002, 09:48 AM
LX98Civic's Avatar
Does the grade of bolts matter? I got some automobile bolts from Pep Boys that are only threaded half way up and then I got some from ACE that have 8.8 on the head. The guy (ACE) said those bolts weren't as strong as the steel ones......
So, I am concerned about the bolts and 1/2 degree of correction for each bolt. Damn, I'll need like 5 washers on each bolt (is that even safe?)....
How long have you had 5 or 6 washers on each bolt?
Old 04-11-2002, 03:46 PM
For almost a year now. Yeah it's safe because it still protudes decently into the chasis, unless I crash or something, it'll hold.
