Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 05-08-2005, 05:46 PM
vt52now vt52now is offline
Angry Antennae won't go up
Problem with my 95 Subaru Impreza is that one day I went to turn on the radio and nothing. My antennae won't go up. No sound, no nothing. Can anyone help me??? Thanks.
Old 05-08-2005, 06:00 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Antennae won't go up
Could be a fuse or something that powers the radio.
Old 05-08-2005, 06:52 PM
Re: Re: Antennae won't go up
Checked fuse - it is ok
Old 05-08-2005, 11:47 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
Non-power antenna?
Hell my 02 doesn't have a power antenna, you have to reach out the window and pull it up and down.
Old 05-09-2005, 09:36 AM
freakray freakray is offline
AF Modelrater
Subaru Imprezas have never come with a power antenna.....
AF User Guidelines
Old 05-11-2005, 05:37 AM
Right_LiRrr's Avatar
Right_LiRrr Right_LiRrr is offline
Send a message via MSN to Right_LiRrr
My one is embedded in the rear windscreen. Perhaps different on American models.
Oh, I just saw yours is a 95....disregard.
Rob
Old 05-18-2005, 07:48 PM
SUBARU_TECH SUBARU_TECH is offline
after checking the fuse,disconnect the connector at the motor.if you are limited in test tools.use a test light across the terminals.if it lights up as you turn on the radio must likely its the motor.the proper way is to test at the connector with a meter to check or current draw/voltage.a good homemade test light from a sealed beam headlamp with leads installed will give almost the proper current draw.only use this tesy lamp on non computor controlled harnesses.
