Old 05-08-2005, 05:08 PM
cf1 cf1 is offline
should i remove the bed
i need to replace the fuel pump in a 93 chevy 1/2 ton full size. is it easier to remove the bed or drop the tank...
Old 05-08-2005, 08:42 PM
OverBoardProject OverBoardProject is offline
Banned
Re: should i remove the bed
Wrong forum, but the answer from easiest to hardest is
1 - cut a hole in the box (and have the piece that you cut out made into a cover) above the fuel pump, and big enough to remove it. This can of course be used to replace it easier in the future.
2 - raise the box, you can probably get away with tipping the box towards the filler side.
3 - And removing the box is the hardest, although really not that bad
Old 05-08-2005, 08:51 PM
blazee's Avatar
blazee blazee is offline
Problem?
You should check the fuel pressure before replacing the pump. Most Autozones will have a fuel pressure gauge as a loaner tool. You just pay for it, return it within 3 days and they'll give your money back. Did you ask them about a loaner tool or did you just look at the new ones?
http://www.automotiveforums.com/vbul...d.php?t=401806
Old 05-09-2005, 10:04 AM
cf1 cf1 is offline
Re: Re: should i remove the bed
ato zone wont rent that tool you have to buy it. i bought a pump and filter i will install today. you can hear the pump making a rattling sound in the tank. a few weeks ago i was pulling tree stumps out and mabe something pulled lose//
Old 05-10-2005, 02:34 PM
jg95 jg95 is offline
I took the bed off to replace my fuel pump took me about 2 Hours. I thought it was pretty easy and quick for never doing it before.
Old 05-10-2005, 02:46 PM
dugie6551's Avatar
dugie6551 dugie6551 is offline
You do not have to remove the bed ... unless you want too.
Remove the gas tank strap bolt and the (3) three bolts for the front support on the outside of the frame and drop the tank using a jack. There will be enough play in the fuel lines to lower it enough to undo the fuel line clamps. A tip I have done: replace the first 2'-0" of the hard fuel line from the tank along the frame forward to the front of the truck. Next time you need to remove the tanl you can undo the lines from in front of the tank instead of above it.
Good luck trying to remove a full size bed without a bunch of friends to help you !!!!
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 05-10-2005, 07:01 PM
Banned
Wink Re: Re: should i remove the bed
Good for you
Old 05-11-2005, 01:25 PM
cf1 cf1 is offline
Re: Re: Re: should i remove the bed
Originally Posted by OverBoardProject
Good for you
i removed the straps it took an hour, just put new sender and fuel pump in it took about 35 minuts .
Old 05-14-2005, 11:44 AM
bigblackone bigblackone is offline
good for me ... my bed is already off ... ( bodywork/shaving/paint) so I have good access to it ... now I just gotta get the part ( sending unit) and pop it in.
Old 05-14-2005, 07:32 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: Re: Re: should i remove the bed
I took my bed and bumper off and changed sending unit in about 45 mins.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 02-07-2006, 06:26 PM
brosko80 brosko80 is offline
just drop the tank. i think that is the coorect way to do it
Old 02-07-2006, 08:04 PM
Banned
Either way is fine, but this thread is 9 months old. Unless you need some extra info on the subject there is no need comment on it, which brings it to the top.
I don't mean to sound like an ass. It's just a board policy.
