Old 05-08-2005, 02:23 PM
1Low S-Dime 1Low S-Dime is offline
Is valve tap bad?
Okay, this should be my last thread posting, I've already posted enough. Really simple question: is valve tap bad? I've just noticed that after the engine warms up, I guess, you can hear a slight tapping noise coming from the driver side valve cover, my guess is that it's a valve tap and needs to be tightened down some. I'm going to slightly tighten them anyways, but I am curious, is valve tap bad?
Old 05-08-2005, 03:20 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Re: Is valve tap bad?
ive herd of cars that run a long time with rockers taping and that sort of thing it can only be a problem if yer hard on it but if you know what to do just fix it
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 05-09-2005, 06:58 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Jason, change your sig, too farking big!
Old 05-09-2005, 11:17 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Re: Is valve tap bad?
I second this
Old 05-09-2005, 11:24 PM
Banned
I'm told that silght valve tap is fine. You don't want them too tight though.
It isn't too hard to adjust them, but it's messy.
Remove Valve cover, run motor, back off nut until they tick, then re-tighten it until ticking stops, tighten another 1/2 turn. Only do 1 valve at a time and make sure that the oil is right up there before you start
Look at the exhaust manifold and gasket first, you probably have a small leak causing the noise.
