Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-08-2005, 01:44 PM
mikesoob7 mikesoob7 is offline
Location of Air Temp Sensor and IAC?
Does anyone have a pic or is willing describe to me the location of the air temp sensor and idle air control valve on a 97 SC2? If the air temp sensor is where I think it is do you have to remove the intake manifold to actually remove it?
Thanks,
Mike
Old 05-08-2005, 03:03 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
intake air temperature sensor is on the air box. i believe the front of it, cant remember since my stock air box is gone. now going from many other cars, again i dont remember exactly where the iac is at, but its on the throttle body and i think its the top one if there is a top sensor. on the side of the throttle body should be the tps sensor.
Old 05-08-2005, 04:09 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Location of Air Temp Sensor and IAC?
the IAC will have two or four wires, the TPS will have three, they are both on the backside or the throttle body.
Old 05-08-2005, 04:28 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Post
I could never find the IAT sensor either. It is supposed to be on the air box/snorkel. The IAC valve is located to the rear of the throttle body. It is held on by 2 torx screws that face the firewall. I took the TB off rather than risk loosing the screws when I went to clean the TB and IAC. Glad I did too. It was so much easier to see inside the IAC port to be sure it was clean. The TPS sensor is located directly over the butterfly pivot. IAC
Old 05-08-2005, 04:30 PM
mysatilac's Avatar
mysatilac mysatilac is offline
These are off a '96 SC2, but they should be identical,
Had the parts and a camera laying around, so...
If a picture is worth a thousand words heres a few thousand words
IAC (idle air control) Valve, Both pics are with the TB upright
Intake Air Temp. (IAT) sensor, its removed but thats where it goes
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 05-08-2005, 04:43 PM
peppermrj's Avatar
Ahh said the blind man to his deaf daughter. thanxs for the pixs also.
If you pull the IAC don't lose the little $11.25 dollar o-ring. Dealer only item.
Old 05-08-2005, 04:56 PM
mysatilac's Avatar
Re: Re: Location of Air Temp Sensor and IAC?
No Prob.
True that,
Also be careful with the TB gasket and you can reuse it,
Its like $13, special order from Auto Zone,
Old 05-08-2005, 05:57 PM
i think the gasket is cheaper at the dealership
