Old 05-08-2005, 11:31 AM
jd87sep jd87sep is offline
Send a message via AIM to jd87sep
switching to posi
i have a 1992 rs, with a standard differential. I know a guy with an 88 iroc with the rear-end i want, but it's got disc brakes, and I've got drum brakes. Is it easy to convert from disc to drum on a rear end?
Old 05-08-2005, 07:45 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
okay i did that swap for my 91 rs w/ an 87 iroc rear...u will deff. need the porportioning valve for that car or an adjustable one....and a new master cylinder..also make sure that the rear still has the ebrake bracket on it cause the one i got didnt so when i bought after market calipers the didnt work right w/ out it it seemed like they let the brake pad wobble a lil sometimes....and the rotors for that rear should do u for the brake part of it. but be warned when i did the swap i shredded the rear cause the gears that were in it were the wrong ones w/ the wrong spline count for my axles so u need to make sure cause i had to just shell out 1527 bucks to redo the whole rear in mine, i have a post mabey one or two pages out explainin it a lil check it out if u want to
Old 05-08-2005, 08:21 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Jesus, for a 1500 you could buy a NEW rearend and extra stuff.
Old 05-08-2005, 09:37 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: switching to posi
1527?!?!?!?!?! did you need the entire differential rebuilt?!?!?!?! otherwise you were RIPPED OFF
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 05-08-2005, 09:44 PM
yeah it shredded the posi unit i looked at it so i got the posi unit from eaton, the ring and pinion and deluxe install kit from richmond gears, outter seals, and i got new wheel bearings while they were in there cause mine where pretty shot....and about 600 for labor so the only thing that wasnt new was the carrier
