Old 05-08-2005, 11:14 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Question whats better?
hey i was just wondering what is better on a 3.8 camaro? a supercharger or a turbo or neither? also what should you have done to the engine before installing either of them?
Old 05-08-2005, 12:17 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: whats better?
I think if you wanted to you could run either. I am not certain on the installation and plumbing needed to run them however. As far as doing engine work before installing them you don't have to but if you don't you can only run a small amount of boost otherwise you'll raise the compression ratio too much and get detonation. I'm not sure on the amount that you would be limited to but I know you'd have to run less boost than if you did some work to the engine.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 05-08-2005, 02:04 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: whats better?
each has its pros and cons... but yeah don't plan on runing too much boost on stock internals
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-08-2005, 02:13 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: whats better?
Both will create virtually the same wear on an engine. The turbo will cost slightly less to get than the supercharger and the turbo will give some more hp.
White 07 STI, Bone stock for now
Old 05-08-2005, 03:29 PM
Re: whats better?
doe turbos do much harm to the engine? would it be worth it or is it a bad idea? and how much do you estimate the cost when its done? thanks
Old 05-08-2005, 11:34 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: whats better?
cost $2500-4000.
turbo would be more difficult to install that supercharger.
check out procharger.com
if you want more than 40-60% power gain you need to modify internal engine parts, compression, crank, pistons, rods, etc.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-08-2005, 11:44 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Well if Hypsi was on he would say go with the turbo and then give a thoughtful lecture on what to do so, I would say just wait until he gets on and just follow what he says to do to the engine to the letter.
Old 05-09-2005, 01:35 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: whats better?
it needs some thik really thik gaskets to lower the compression ratio, $8oo bucks, healphy engine, some custom plumbing and manifolds, computer, blow off valve two turbos, head work to avoid detonation, intercooler, bigger injectors, fuel pump, and some guy to make it work. U might get around 500-600 hp. I have seen 400 hp civics-and thats a 4
Old 05-09-2005, 01:37 AM
Banned
Re: whats better?
also a laptop too
Old 05-09-2005, 04:27 PM
Re: whats better?
dang sounds sweet.... i think i wana try it when i get my 3.8 camaro.....hopefully that will be soon. im gona go get another job and my freinds dad is a mechanic and hes gonna hel get the word out that im selling my 2.8 camaro. but if anyone has any more info on putting turbos or superchargers in lemme know, thanks
Old 05-09-2005, 04:41 PM
Is eating.
Are you selling the 2.8 engine or the whole Camaro? Because hell if you're thinking about putting turbo with a 3.8, i'd put it in the third gen because to ME it seems like it has more hood space than the 4th gens. And since you're chaning out alot of stuff to make the engine turbo compatable id be better to just get the 3.8 and do all the stuff, and once again I say wait for Hypsi.
Old 05-09-2005, 05:09 PM
Re: whats better?
whole camaro. well if i had the cash to do that i would but my freinds dad is trying to get me 3000 for my car which would be extremely sweet cause i got it for 1000 and i only put like 800 into it. so if he does sel it for that much then i will have like 4300 to get a new car and im getting another job so i will have some money coming in and i will hopefully be getting enough money for a turbo or supercharger.... or is there a better way to get lots of power that costs less.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 05-09-2005, 05:12 PM
Is eating.
Alright to be honest, a turbo is really the best way to get a nice amount of power, but I really would say to wait for the money to be saved up because if you're working on it while you're using your money you are currently getting through your job, you wont finish the turbo mod. BUT I still recommend staying with the 3rd gen because 3rd gens are cool man.
Old 05-09-2005, 05:13 PM
Dober89 Dober89 is offline
Re: whats better?
I thought that turbos were more expensive because theres more plumbing to do when installing them??
Old 05-09-2005, 05:19 PM
Is eating.
Yes turbos cost more than some engines, but not all, like a new LS1 from a dealer.
