Old 05-08-2005, 08:44 AM
pwerz pwerz is offline
Stalling when stopping
98 windstar with 3.8l when coming to a stop I notice that the rpms drop rather low then return to normal.Some times she will stall out and I can start it right up. Any ideas on where to start looking?
My mechanic tells me its common and there is a kit u can install to prevent this . Does this sound real ?
Old 05-09-2005, 12:38 AM
wiswind wiswind is offline
Re: Stalling when stopping
One common cause of this problem is the Idle Air Control (IAC). This controls the idle speed (via control from the PCM) when your foot is not on the accelerator.
The IAC is on top of the upper intake manifold, right next to the throttle body. 2 bolts and an electrical connector. You might try removing it....and spraying some SeaFoam into it....as it sounds like it is working....but sticking. It is easy to replace also....if the cleaning/lubrication does not work.
Old 08-27-2005, 08:55 PM
fcrew fcrew is offline
If it happens when its warm, I would try replacing the "O" rings under the plastic intake.Over time they tend to suck up some oil and cause a slight vacuum leak.
Old 08-29-2005, 07:16 AM
DRW1000 DRW1000 is offline
Re: Re: Stalling when stopping
Just wondering..............wouldn't a slight intake leak cause a code and CEL?
Old 08-29-2005, 02:00 PM
12Ounce 12Ounce is offline
You might try stopping using only the hand brake. If the stalling problem doesn't occur, you may have an issue with the foot brake vacuum booster.
