Old 05-08-2005, 08:43 AM
1Low S-Dime 1Low S-Dime is offline
Question Do I really need this fuel pump?
Recently I have installed an Edelbrock Performer Intake Manifold, Performer Camshaft, Edelbrock Tubular Exhaust Headers, and a Holley 670 CFM Two Barrel Throttle Body on my '90 S-10 4.3L. When I purchased all of these parts, I also purchased a Venom Hi-Flo fuel pump.
My question is do I really need to replace my current existing fuel pump with this one or can I keep the stock one? If I can keep the stock one (hopefully), I can send this one back and get my money back, and it'll save me from dropping the tank.
On a side note/question: Edelbrock says not to use 2 inch bore throttle bodies on their intake manifolds. With that in mind, I asked a mechanic friend about that and he said that "no, it shouldn't be a problem", of which I kind of thought about it and realized that the manifold just re-mixes the air/fuel deal, which he said "pretty much". So, does anyone else think it's a problem that I have this new Holley TBI unit with a 2-inch bore is a waste of money? (Pretty much my stock one is stuck on the old manifold due to a torn off head on one of the TBI bolts)
Any answers/suggestions are appreciated.
Old 05-08-2005, 09:41 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: Do I really need this fuel pump?
the stock pump only puts out 9 to 14 psi(which is good for stock tbi and intake). the new tb and intake may need more. does it specify in any of the installation paperwork on fuel pressure?
Old 05-08-2005, 01:45 PM
No, the instructions never said anything about adding in a new fuel pump. And, I found out that you should keep the stock TBI unit, so from the sounds of it, the stock fuel pump will do just fine.
Old 05-08-2005, 10:35 PM
jackass#1's Avatar
was it because of the new intake that you couldnt use the holley?
Old 05-08-2005, 11:02 PM
Yes, I asked a mechanic. He said that the intake was designed to utilize the stock unit and that I will probably just waste gas with this oversized one.
