Old 05-08-2005, 02:50 AM
Nate367 Nate367 is offline
No Data from connector
Hi everyone
I just bought a 96 Sunfire last month for my sister and the car wont start. I have spark, fuel, good compression and air flow. When I hook up a Scan tool to check my injector pulse etc. it says "No Data." I found a test for this symptom which checks voltages at the data link connector and continuity on the number 2 terminal of the connector and everything checks good so it says replace the PCM. So I did for $400 and it still the same. I tried my friends snap on scanner and it reads the same as my OTC 4000 enhanced, No Data, anyone come across this and know the cure?
Old 08-24-2005, 08:55 PM
rockdude rockdude is offline
Re: No Data from connector
check cig lighter fuse it is the same power feed for aldl connector
