Old 05-07-2005, 08:56 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Angry It wasnt the coil!!!!!!
Ok, i replaced the coil with a brand new one, and still it wont start. now i poured some gas down through the tbi into the intake, and the car still didnt start. im starting to think either spark plugs or distributor. does my car have a electronic control module in the distributor. does it sound like the distributor to you guys?
Old 05-08-2005, 12:53 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: It wasnt the coil!!!!!!
well, changing the plugs, wires, cap and rotor are basic maintanence and is fairly inexpensive, so i'd go ahead and change those and see where it gets you. If it still doesn't work then i'd start looking at the distributor. wait and see if anyone else has a better idea tho. actually before you replace anything, run some spark tests.
Old 05-08-2005, 02:54 AM
Morley Morley is offline
Ignition module Tango Uniform, if you don't get spark of any kind. Pull the cap and rotor, the module is under there. Also while in there look at the reluctor (round sprocket looking thing) and make sure it is still attached to the shaft. If it is, replace the module...but ONLY use an AC Delco unit or you'll be replacing it again real soon.
Old 05-08-2005, 10:14 AM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: Re: It wasnt the coil!!!!!!
I would do that espically if you don't know when the last time any of that was changed. It could be something like 1 of your sparkplug wires wnet bad....
White 07 STI, Bone stock for now
Old 05-08-2005, 08:25 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
And then if it isnt getting any spark more than likely its the distributor and remember to get a new rotor with the distributor. Hope this helps.
Old 05-08-2005, 10:30 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
when you take the Ignition control module out, you can take it to autozone (or another store) and they can test it for you to see if it works before you replace it. when you put it back in (or the new one) mae sure you put thermal grease on the bottom, otherwise it will soon be destroyed by heat and you will have to do it all over again.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-08-2005, 10:38 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Re: Re: It wasnt the coil!!!!!!
if a few plug wires were bad u would still get spark... just not for all cylinders
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-09-2005, 07:47 AM
it was the ecm, and i also put a new rotor button on. now my car actually starts as soon as i turn the key over. but it still has a miss, but it has set for a while and the spark plugs are probally in need replacing.
Old 05-09-2005, 08:09 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
ouch, the ECM?? thats a shitty deal.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
