Old 05-07-2005, 07:20 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
codes
anbybody know what a code 16 is? and how you can try and hear the fuel injectors clicking? especially when the engine only runs untill its warm then it dies.
gimme some time. ill think of something witty and clever to put here.
Old 05-07-2005, 11:06 PM
BullShifter's Avatar
Re: codes
Code 16 - Fuel Injector
You can listen to the injectors with a mechanic stethoscope or do it the easy way. measure the resistance between injector terminals. If the resistance isn't between 0.6-1.6ohm then that injector is bad.
Old 05-08-2005, 11:44 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: codes
most likely:
main relay
the solder joints go bad and then you get no contact and then your fuel pump won't turn on, setting off the code 16 (OBD 0 computers aren't very specific). Do you have trouble starting your car after it's sat for a few minutes, like it will just turn and turn over with nothing, but then it will start in a min or two? That's the main relay. I had the same problem and just fixed mine yesterday, hardest part is getting to the damn thing.
