Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-07-2005, 07:12 PM
caginvstg8 caginvstg8 is offline
Send a message via AIM to caginvstg8 Send a message via Yahoo to caginvstg8
keyless entry programing
Does anyone know how to reprogram the keyless entry remote for a 1998 Contour?
Thanks
Old 05-13-2005, 08:49 AM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: keyless entry programing
Cycle The Key 8 Times - The Doors Should Lock And Unlock And Then Press Any Button On The Remote - The Doors Should Again Lock And Unlock - Turn The Key Off And Done
-=-=-DANE-=-=-
Old 05-19-2005, 08:20 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Instructions:
Turn ignition to RUN or ACC. Momentarily jump pins located in programming connector behind glove box. The horn will chirp to confirm programming mode. Press any button on 1st transmitter. The horn will chirp to confirm programming. Press any button on 2nd transmitter ( up to 4 transmitters total possible). Turn ignition to OFF. The horn will chirp one last time to indicate end of programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 07-16-2005, 02:40 PM
Slow5.0 Slow5.0 is offline
Send a message via AIM to Slow5.0
Anyone knows where is Keyless remote located in 99 Countaur LX and does LXs came with that
Old 07-19-2005, 08:43 PM
Anyone ???
