Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-07-2005, 07:29 PM
4g63engine 4g63engine is offline
Send a message via Yahoo to 4g63engine
Unhappy problems with eclipse fire trowing
i have an eclipse gsx turbo and i dont know what to do i bout a maft translator but i dont know how to set it. before i bought the maft i had problems with the car hessitating at 3000 rpm but everything else was right. now with the translator there is not enough air to pass 2000 rpm and also is trowing fire from the exhaust and shaking a lot dos somebody knos about something like this. really need help i dont want to sell this baby!
Old 05-07-2005, 09:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: problems with eclipse fire trowing
first of all put back your stock mas until you fix the problem. adding aftermarket parts rarely fixes problems and usually makes it harder. the hesitating sounds like a boost leak.
what mods do you have?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-10-2005, 01:17 PM
hi thnx for reply the only things i have are bov,3"fmic,valve breather,injen intake,k&n air filter, and 2900 act with act light flywheel. hopefully this will help. thnx
Old 05-10-2005, 09:41 PM
are you venting your bov. if you are put it back the right way until the maft is installed and working right
-1stGenRocks-
Old 05-11-2005, 02:04 PM
hi i forgott to mention that the air condencer its not on its place i got rid of it and i still waiting for a new one do u think this is affecting? thnx
Old 05-13-2005, 07:07 PM
do you mean the air conditioning condenser? that wont affect anything as long as your ac belt is off.
-1stGenRocks-
Old 05-14-2005, 12:35 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Re: problems with eclipse fire trowing
i think you mean...
3in intercooler pipes...valve cover breather.....act 2600 clutch....
these mods are very random and your running a stock turbo ??
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 05-14-2005, 01:11 PM
well i think the problem are the pipes and the breather because i had the 2900 clutch before and it was working wood. to be honest i did something call !@#$%^ what i did is that i cleaned the air filter and i didnt wait for it to get dry so i think some how the maf sensor got some water and that is the reason y its not working good anymore. the problem here is that i already bought 2 maf sensors trying to fix the car but the problem persists. what should i do?
