Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 05-07-2005, 06:05 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Howling Noise
my mom has a 02 aztec and when ever moveing you hear a howling noise coming from the front end so i think but this didnt start until she had the tires rotated and she before has had them done regularly so i dont no any advice would be great
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 05-08-2005, 12:19 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Howling Noise
Two things could be wrong. First the tire could be worn and causing the noise you hear, this would be the cheapest and easist thing to repair as you simply replace the tire. The other would be the a bad wheel bearing that would cost a lot more to replace as you will probably have to take it to a mechanic or dealer. I would try the tire first and then only after you have replaced it if the noise continues, I would have the wheel bearing looked at. My money is on the tire!
Old 05-08-2005, 08:42 PM
i knew it was one of those two but it just started when she had the tires rotated so yea ill check the tires
Old 05-08-2005, 10:12 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Howling Noise
Normally I would blame a wheel bearing, but in this case, I wonder if something was damaged or is interfering with the rotation of the tire.
The easiest thing to do is to rotate the tires back to where they were and see if the noise changes.
If not...its wheel bearings or brakes.
Old 05-09-2005, 02:35 PM
ohiogoodguys ohiogoodguys is offline
Banned
Re: Howling Noise
Unfortunately I think I would look at the wheel bearing first before the tires. The Azteks are well known for having wheel bearing problems and mileage means nothing. You'd want to get it in the air, somewhere you can trust the mechanic and have them check it. I had one on my 01 go bad and I know of many other posts over on the Aztek Fan Club about the wheel bearings.
The wheel bearing problem is not just Aztek specific but seems to be a GM problem. I had an Oldsmobile with the same problem. The wheel bearings are pricey since they have the ABS sensors in them.
Jack
Old 05-09-2005, 03:15 PM
it sounds like a bearing but at just under 30,000 miles i dunno ill try rotateing the tires back
Old 05-09-2005, 04:05 PM
Banned
Re: Howling Noise
Since it's still under warranty get into the dealer and have the bearing replaced.
jack
Old 05-19-2005, 03:57 PM
BuDog BuDog is offline
Once I put on the luggage racks backwards and they caused a real howling noise that obviously increased with speed. Make sure the luggage racks are on correctly.
Old 05-19-2005, 04:01 PM
Banned
Re: Howling Noise
I have had both and you definitely can tell the difference. I would still think bearings.
Jack
Old 05-23-2005, 03:48 PM
batmobile78m batmobile78m is offline
had exact same problem
2002-25,000 miles
dealer said they replaced hubs and sound went away.
Old 10-30-2005, 10:44 AM
jkayhome jkayhome is offline
Re: Howling Noise
Don't know if you ever got an answer to this but I have a 2001 and had that problem, turns out there was a bulletin on the rear-end. They had to replace it. If you haven't gotten it fixed yet, check with the dealer about the bulletin on the rear-end. They won't tell you about it because it is expensive.
