Old 05-07-2005, 01:51 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
throttle body
Hey guys, will the stock throttle body be a direct fit to a 3 inch intercooler pipe or would I have to do something else to make it fit?
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 05-07-2005, 02:29 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Im pretty sure the factory 2g throttle body is 2" but I may be wrong.
ok just did some measurements and I got that the actually pipe comming off is about 2 1/4" big and my pipe that I have on there is about 2.8" I dono if 3" would fit though, I would just guess and check. Just remember that for the upper piping the larger you use the more lag you could potentially have. but larger lower piping is good.
Old 05-07-2005, 06:56 PM
shadow eclipse shadow eclipse is offline
Send a message via AIM to shadow eclipse
I have been wondering about this too. My intercooler has 3 inch inlet and outlet. Anybody ever use 3 inch? Gains? Draw backs?
95 GSX 14.748
90 GSX
Old 05-07-2005, 07:57 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: throttle body
On a smaller turbo, 3" intercooler piping is only going to hurt performance (mainly spool-up). Larger turbos can fill that 3" intercooler piping much better and will actually see airflow gains with it if the entire intake tract is 3" up to the intake manifold (so a 3" TB would be needed). 2.5" intercooler piping is more than enough for the majority of turbos smaller than a "60 trim", IMO.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 05-07-2005, 08:23 PM
Re: Re: throttle body
Sweet, thanks man, Now All I need is a big ass turbo..LOL
95 GSX 14.748
90 GSX
Old 05-07-2005, 11:10 PM
Ya, I will be upgrading to an evo3 16g when I get some money. I only ask this now cause on ebay, there is a really nice core for $185, but the inlet and outlet are 3'
Old 05-07-2005, 11:30 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: throttle body
It doesn't matter if the inlet/outlet is 3''. That's what reducers are for. 2.5 is more like it, nobody is running 600whp.
Old 05-08-2005, 07:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: throttle body
I made a 3 inch to 3.5 inch UICP, but I had specific reasons (needed to fit 3.5 inch GM MAF with no abrupt transitions). You should be able to see it at www.posracing.net/bigmaf.html if I didnt pork the URL. Most FMICs come with 2.5" piping and TB elbow. The TB inlet is barely 2.5 inches, the bore of 60mm is 2.36 inches. Sp going bigger doesnt help in the flow department. I Went to a NT TB that accepts a 3" silicone coupler (with 2.75" spacer) just to make fitment easier, not for flow.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-08-2005, 11:38 AM
So having full 3 inch intercooler piping would not be good even if you had a 3 inch throttle body? Is it really going to cause alot of lag? Alot of pressure drop? Or any noticable diffrence at all?
95 GSX 14.748
90 GSX
Old 05-08-2005, 10:40 PM
JoeWagon's Avatar
Banned
Re: throttle body
You have to relate things to the proper causes. Just increasing the TB to 3'' isn't going to make 3'' IC piping 10 times more effective. Yes, it will cause more lag because the inner volume of the piping is larger. Yes it will cause pressure drop. On a side note, a lot of higher power cars have stock TB's, which are really restrictive. Hal Landry is currently doing the Q45 80mm bore TB to 3.5 GM MAF... I'm excited to see how it works out.
Old 05-09-2005, 09:50 PM
Ok, thanks guys!
So what I'm getting out of this is to run 3' pipes on the lower end, but use a reducer to 2.5' for the uicp to the tb?
Old 05-10-2005, 09:19 PM
twisted_wrist twisted_wrist is offline
Send a message via MSN to twisted_wrist
Yeah
Yes it will work, coz I have that on my set up on my 98 GST.
Attack life, it is going to kill you anyway.
