Old 05-07-2005, 01:45 PM
Johnny916 Johnny916 is offline
2002 Ford Windstar Check Engine DTC P0171 "System Too Lean"?? Help
Hi, I pulled up this code P0171 because my check engine light is on.
Can somebody tell me how to start trouble shooting the problem??
Here's what I looked up so far:
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously
monitors fuel delivery hardware. The test fails when the adaptive fuel
tables reach a rich calibrated limit. For lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value
between -35% to +35% is acceptable. Reading beyond these values indicate a
failure.
I need a trouble shooting flow chart!?? I have a 2002 Ford technical publication but I can't find any flow charts on it.
My email is: [email protected] and it would be MUCH appreciated if somebody could send me something.
Old 05-07-2005, 07:41 PM
DRW1000 DRW1000 is offline
Re: 2002 Ford Windstar Check Engine DTC P0171 "System Too Lean"?? Help
Search this forum...............P0171 is the most common code for Windstars and the troubleshooting of it has been discussed many times over.
Old 10-29-2009, 06:47 PM
brian25 brian25 is offline
i have a 2000 ford windstar and i have the same codes on my van is p0171/p0174 how do i fix it the right way please thank you my email is [email protected]
Old 10-29-2009, 07:08 PM
veerg veerg is offline
Read the frigging first line on the main page.
Old 10-29-2009, 09:21 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
do a vacuum test to see if you've a vaccum leak.
this is what I had in my 99 Windstar.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 10-30-2009, 08:28 AM
mundy5 mundy5 is offline
Johnny and Brian, go here and look at PCitizen's post.
http://www.automotiveforums.com/vbul...d.php?t=338113
Through PCitizen's link, you will find detailed step by step pictures and instructions of making this fix. It is such a common problem that Dorman and other 3rd party parts manufacturers actually sell a kit (Isolator Bolt Kits) to fix this problem.
If you follow it step by step, you will eliminate the problem once and for all. Going on 1.5 yrs now.
2003 Windstar LX
1998 4dr Civic LX
Old 10-30-2009, 06:13 PM
This Website is good also: http://www.leckemby.net/windstar/windstar01.html.
I used it to repair my problem.
