Old 04-09-2002, 11:41 PM
changedagame108 changedagame108 is offline
Cracked wheel lock update: pic inside...
Here's how the damage looks like:
I've asked several tech people and they suggest either drilling the remaining bit of the lock with a dremel, carefully of course, or using needle-nosed vice grips to try to rotate the remaining piece out. Any suggestions?
Old 04-10-2002, 04:33 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
a couple way to attack this without damaging the wheel...
drill two small holes in the leftover of the lock, opposite of each other, then use the tips of needle nose pliers to get it out. if it's still torqued, then you're kinda screwed... use a drill to drill out the lug stud and install a new stud once the wheel comes off.
Old 04-10-2002, 04:37 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
Drilling grade 8 steel...fun!!
Old 04-10-2002, 04:51 PM
mike187's Avatar
mike187 mike187 is offline
did you try getting a bolt with reverse thread so that when you are tightening that bolt you will unloosen the lug. i can't really tell from the pic how deep the hole is drilled to tell if it will work but it might be worth a try.
Old 04-10-2002, 06:20 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
I would cut the stud from behind with torchs and drive it out with a zip gun,that way it wouldn't damage the wheel.
In fact I already did that once on a Caravan,might work on a Civic too.
Having a fully equipped shop can be cool sometimes
Proud member of AF's Lazy crew
Snow,snow let it snow
Af Nordic crew #008
team drift cat official member#5
Originally posted by sparq
CANADA RULES :finger:
CANADA RULES -- thats all that matters :ylsuper
Old 04-10-2002, 06:41 PM
How much is a new stud and how difficult is it to install?
Old 04-10-2002, 07:10 PM
89ssgti's Avatar
maybe 2 to 3 $ plus a new nut,basically,you take off all of the brake component,then drive it in from behind on the hub.
Af Nordic crew #008
Old 04-10-2002, 07:38 PM
Thanks for the info man. Actually, this one shop might be able to work on it for me so I'm hitting it up tomorrow or later on this week. Hopefully the repairs won't cost me an arm and a leg!
