Old 05-07-2005, 11:08 AM
franger franger is offline
sick 98 windstar
hi all
wondering if anyone has had any experience with a 3.8l spitting out a P0442 code - evaporative emmission control system leak detected (small leak). started last summer, tried the gas cap, checking for split hoses, purge canister and solenoid, and then, magically, as the cold weather came in, the cel went away (after clearing it) and stayed off until a month ago, with the warmer weather. any help appreciated. also, abs light on, any suggestions on common faults or other recommendations with this system appreciated.
Old 05-07-2005, 07:39 PM
CoachKarl CoachKarl is offline
Re: sick 98 windstar
Hello Franger, What model year, how many miles on it?
Old 05-07-2005, 11:45 PM
wiswind wiswind is offline
ABS light....Check brake fluid level....
ABS light comes on if it is just slightly off the full line.
Old 05-08-2005, 06:25 PM
Re: Re: sick 98 windstar
1998, 71 000 mi
Old 05-08-2005, 06:29 PM
that was the first thing i checked, ok. one thing i forgot to mention was that lately, once in a while the brakes pulse as if the abs was being actuated, on dry pavement.
Old 05-17-2005, 03:32 PM
bump
Old 05-17-2005, 05:23 PM
DRW1000 DRW1000 is offline
Dirty wheels sensors can cause ABS light. You can clean the rears by removing the sensors from the back. (It didn't fix mine though).
Old 06-28-2005, 05:19 PM
hi all
just following up on an abs light fault. turns out it was a c1141 fault, cracked toothed ring on the drivers side. to remedy the problem, the entire drivers side axle assembly had to be changed out. the mechanic said that fix was same price as changing the outer cv joint (which the toothed ring is part of) and boot. remanufactured axle $280 (incl core charge), diagnostic charge $55, labour $65. thankfully i had a beer to cry into when i came home!
