Go Back   Automotive Forums Car Chat > Ford > Probe
Old 05-07-2005, 10:32 AM
blindfoldedhope blindfoldedhope is offline
Send a message via AIM to blindfoldedhope
Klze Info Need Help!!!
Ok my car started knocking im going to order a KLZE and i need some info on it
1. Will it work with A-spec Ecu
2. Same Water Pump And timing belt?
3. Direct Fit?
4. Same wire Harness
5. Any other INFO!?
Anyones help will be greatly appreicated Thanks
Old 05-07-2005, 10:39 AM
Oh Yea
I live in NJ do you think it will have a problem with emitions....?
ANd is the tranny a direct bolt up...
Kinda NEW to the KLZE's Thanks
Old 05-07-2005, 12:59 PM
joshs93gt joshs93gt is offline
Send a message via AIM to joshs93gt
all of your components should bolt on directly. as for emissions, i have no clue. i don't have emissons by my house cuz i live in bumfucked egypt. but your supposed to use your altenator and all of the components that were already on your car, if they are still working. i'm pretty sure u will need new belts though. i'm not possitive, for am i sorta new to klze myself, but this is what i have found out from reading around on the internet about them. ebay has good prices for klze engines. try there first.
93 PGT
CherryBomb Glasspack
3A Racing exhaust
Tokyo Coil Over Springs
Sony X-PLOID Reciever
Kennwood 1000watt amp
4 8" Aria Subs in custom box
Old 05-08-2005, 03:59 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: Klze Info Need Help!!!
evrey thing will work as far as belts yes they will work to i would recomend changing your timing belt and valve cover gaskets and might as well change the oil pan gasket to,i didnt do any of this but i wish i did i leak about a quart of oil between oil changes and i need to do my timing belt its a lot cheaper out of the car
Old 05-10-2005, 02:42 PM
Yep just bought a new water pump and timing belt im getting some new pullys sparks wires and a cold air intake this should come out sweet
