Go Back   Automotive Forums Car Chat > Toyota > Tundra
Old 05-07-2005, 08:40 AM
Mattchiro Mattchiro is offline
Question Check engine light question
I have a 2003 limited and the pesky check engine light came on after going over a bump in the road at 35 mph. I had just filled her up for the first time and didn't fully tighten the gas cap, so I think that is the likely cause. So how can I reset the computer myself? I've heard about disconnecting the battery possibly. What about simply pulling the fuse to the OBD?
Old 05-07-2005, 01:36 PM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
Re: Check engine light question
Both ways will work, or you can simply just let it reset itself. Should be just a couple of days. Mine went off after two days. Good luck!
WAR UTAH!!
Old 05-09-2005, 08:40 AM
Re: Re: Check engine light question
It's been over a week now and there have been about 20 key cycles and it still burns bright. Does it always reset itself?
Old 05-09-2005, 07:38 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
Disconnect the negative terminal for an hour or two. That will reset the light for sure.
Old 05-10-2005, 06:37 PM
Ando140 Ando140 is offline
Not sure if this will work with the tundra, but it always worked with the tacoma I had. Disconnect the positive battery terminal for about 5 minutes, that should reset it.
Old 05-11-2005, 11:34 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Pull ECM fuse
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
