Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-07-2005, 12:23 AM
rcneclipse rcneclipse is offline
Angry turbo help PLEASE!!!
i have a 97 eclipse rs, i have installed a ts ts turbo kit but it will build boost. i want my guague to read more than 0!!! what are some things to check. even with no exhaust hooked up, it should still show boost right?
Old 05-08-2005, 08:15 AM
TurbodLude TurbodLude is offline
Re: turbo help PLEASE!!!
Um......wha? I'm assuming you are saying it will NOT build boost? Then there are the simple things....do you hear the turbo spool up? Is your gauge hooked up correctly.....Are you driving in the right car at the time?
BUT then you say with no exhaust hooked up.....which confuses the hell out of me....you are expecting to see boost? Oh brother.
You wont see anything coming from an EXHAUST DRIVEN supercharger with no exhaust hooked up. Your question is very confusing and we need quite a bit more detail than you have given.
Old 05-08-2005, 10:39 PM
sorry about that i was in a hurry. my car wont build boost. so it shouldnt build boost if theres no exhaust hooked up?
Old 05-09-2005, 02:21 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: turbo help PLEASE!!!
THe best exhaust is no exhaust. Quiet yourself or read a book, si vous plait.
If you aren't seeing boost, check for leaks to begin with. What sort of vacuum are you pulling at idle? Have you verified proper wastegate operation? Is the wastegate stuck open?
Kris
2012 Genesis Coupe 2.0t
Old 05-09-2005, 06:20 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
by no exhaust hooked you mean that it's disconnected before the turbo, or after the turbo. turbo's require exhaust gases to spin them, with no exhaust gases passing through the turbo, you won't build boost. are you sure your boost gauge is hooked up correctly?
95 Talon TSI AWD
97 Eclipse GST
