Old 05-06-2005, 09:43 PM
canatto canatto is offline
Hood Alignment How?
I've just noticed for the first time that the hood is a little bit off of alighment in hight with the fender panel in the passenger side. It appears to be sunk below the line a bit. I understand the front hight of the hood can be adjusted by turning the rubber jacking screw up or down, but is there anything for adjusting the hight in the rear end of the hood? I opened up the hood and looked at the hinge area for a few minutes, but didn't find anything that I could adjust with. maybe I've missed something? Thanks for any input.
The driver side hood hight is right at where it should be, by the way.
Old 05-06-2005, 11:08 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: Hood Alignment How?
I wonder if the hinge has been bent? Maybe you could bring the heighth up by adding a couple of washers or shims between the hood and the hinge?
