Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-06-2005, 09:37 PM
David1201086 David1201086 is offline
19" Rims throw off SPEEDO????
Whats up I just order 19" Gianelle V-5's for my 2001 Maxima Gle I was wondering if this will throw off my speedo any and if anyone knows, how much?
Old 05-07-2005, 01:43 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 19" Rims throw off SPEEDO????
Speedo gear ratio is defined by wheel diameter. If that changes, the speedo 'output' changes accordingly.
Compare stock dia to those u buy and calculate offset; u have to measure both with tape. (Even with same tire size codes, difference could be 10% between diff. mfg.)
Old 05-07-2005, 09:44 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
use this: http://www.miata.net/garage/tirecalc.html.
it'll tell you how much your speedo's off by.
my 19" rims w/ low profile tires threw my speedo off by .5 mph @60, so when my speedo says 60 i'm doing 59.5 mph
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 05-07-2005, 01:27 PM
Re: Re: 19
If its only that much I wont even worry about it thanks a lot David
Old 05-07-2005, 10:13 PM
BP2K2Max's Avatar
it depends on how big your stock rims and tires are. i had 225/50-17's and went to 19's with low profiles so the overall diameter of the wheel and tire wasn't too far off from stock, if you have stock 15's or 16's you'll probably be off by a bit more.
BP's Rides;
Old 05-09-2005, 12:22 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
As everyone else here said, if you keep you overall diameter the same, or similar, you should have no speedo problems. Like my stock wheel is 17", and I had a 55 profile tire on it. When I got 19's, I got a 35 profile tire.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
