Old 05-06-2005, 07:57 PM
Scott82 Scott82 is offline
89 CRX Spedo Cable Trouble
Ok i have recently done the ZC Sohc Vtec swap in my HF, and i am using my HF tranny and my damn Spedo cable will not stay in for shit. I have tried everything i can think of to get this thing to stay in but still no luck. Is there some kinda crazy secret to this that i just havn't figured out yet or could something be wrong w/ my spedo cable. Just to see, does anyone have a pic of the tranny end of a spedo cable so i can compare to see if something is missing off mine. And yes i have the little clip thing that is supposed to hold it in on and it seem to grab but is there something else that is supposed to hold the cable in, cause on my tranny there is this little plate thing bolted onto the tranny on a ledge right below the spedo cable so i was also thinking there might be some kinda hold down that i have lost or something. I really don't need the cable that bad cause i know how fast i am going by watching RPMs but it's still anoying cause my odometer dosn't work but on the bright side i am not running up any more miles on the car as long as the cable isn't in but i still would like it to work all the time. Thanks for the help. Scott
Old 05-06-2005, 08:07 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: 89 CRX Spedo Cable Trouble
that little metal plate is suppose to hold it in place. are you pushing in enough cause theres alittle groove on the vss that the plate fits into. is the plate sitting in that groove ?
Team Lonely Drivers
Old 05-06-2005, 08:14 PM
No, the plate is on a ledge below where the spedo cable goes in, i was thinking maybe there is some kinda bracket or something that goes from that ledge to the spedo cable to keep it from moving up and out. You wouldn't have any pics of what your talking about though cause i could be looking at this all wrong
Old 05-06-2005, 09:05 PM
ok looking at the hole where the vss goes into, next to that there should be a threaded hole for a bolt. on the vss itself there should be alittle slit on it. there is a small metal plate the fit into the slit and then gets bolted to the tranny. that is suppose to keep it in. ill go look for a pic
Team Lonely Drivers
Old 05-06-2005, 09:09 PM
look at bolt #19
Team Lonely Drivers
Old 05-06-2005, 09:17 PM
My plate is dosnt reach the spedo cable but it looks like it could possibly hold something down tight that does but i am going to get out in the shop tomorrow and fool with it a little more, it's getting time to do a good over looking since i did the last one after the swap. But if you can find a pic that would be great cause inthe diagram above my little plate that bolts down dosnt look anything like that one. My plate is maybe a hundred thousand's thick if you measured it with some calipers, and there isn't a slot on the tranny where it lines up. I looked thru my pics but couldn't find a good one of the spedo cable hole. I'll try and draw a pic or something and maybe that'll help.
Old 05-06-2005, 09:57 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
my friend had to fabricate a bracket out of sheet metal to hold his in place...dunno why it wouldn't screw into place with the oem bracket but there were a lot of things we didn't understand about that car
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-06-2005, 11:24 PM
stickershop's Avatar
stickershop stickershop is offline
What's all this talk about "VSS"? He has a speedo cable. On 88-91 CRX and Civics the VSS is part of the gauge cluster. The only thing that holds the speedo cable into the transmission is the little clip. Sometimes the clip gets bent too far open upon removal of the speedo cable. Bend it a little more closed before replacing it so that it will actually sit in the groove on the end of the speedo cable.
First, install the speedo cable...make sure it is aligned and goes all the way in. Once it is fully seated in the transmission, slip the clip on the speedo holder so that is sits in the slit on the side. Voila...speedo cable won't go anywhere.
StickerShop.ca - got stickers?
High Quality Custom Vinyl Graphics, Signs, and Banners :thumbup:
Proud owner of two 1991½ Honda CRX Si Special Edition's (sequential VINs too!)
Old 05-06-2005, 11:58 PM
Done that three times, still pops out. I take a machine shop class. i am going to make me a bracket that will hold it in the tranny.
Old 05-07-2005, 02:37 AM
Re: Re: 89 CRX Spedo Cable Trouble
I don't know what the issue is then. I know that with mine fully seated and with the clip installed I wouldn't be able to yank it out with all of my arm strength. Are you sure it's going in all the way? The end of the speedo cable has to line up just perfectly to go in all the way. Last time it took me over 10 mins of screwing around with it just to get it to go in properly.
Old 05-07-2005, 09:08 AM
i wish i had a pic of one all the way in where u could tell just how far it is supposed to go in cause i think it is going all the way in but i could be wrong but as much as i have fooled w/ the damn thing i am begining to think that something isn't right
