Old 05-06-2005, 07:45 PM
thauncle thauncle is offline
Light won't come on why?
my light for my speedometer won't come on so I couldn't see how fast I'm goin at night. I changed the bulb and it still won't work but the other lights work just fine whats the problem?anyone had this happen to them?any advice or thoughts?
Old 05-07-2005, 07:23 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Light won't come on why?
I would check the socket for power when the head lights are triggered. May just be a damaged wire.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 05-09-2005, 01:03 AM
ok
what wires would I check(and what colors and such are the wires) and how would I check them without shockin myself?
Old 05-09-2005, 04:02 AM
Hoags's Avatar
Hoags Hoags is offline
You're not going to gst shocked, it is a low volt system, Check the socket with a test light to make sure you are getting power. This may sound silly but is the replacement bulb good, I've replaced bulbs in the past only to have a bad replacement bulb.( just a thought). Any way if you are not getting power to the socket you should trace back the wires from the socket checking for a bad wire or a pinch or cut in a wire.
Hope this helps
Good luck,
Old 05-12-2005, 02:23 AM
thanks for the help I'll check it out
