Old 05-06-2005, 06:56 PM
scottweeks scottweeks is offline
Torque converter
Can anyone tell me where I could locate the Torque Converter Cutoff on a 92 Grand AM Quad 4. I believe that is what it is called. My car is stalling as soon as it gets too hot and only stalls when in driving gear, Neutral and park are fine, shift anywhere else it stalls.....leave it for about 20 mins and it starts right up.
Old 05-06-2005, 07:39 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Torque converter
Welcome to the forum scott. From what you said, I'm not sure if that's your problem. It actually sounds like it might be your fuel pump - bad fuel pumps overheat after a while, and could stall, especially when shifting, and then they cool off and start working again after a while of the vehicle being off. However, if is your TCC, I believe it's located directly ontop of the bellhousing. It's got four prongs I believe, and I think it's blue. I would wait for someone to verify this though, I don't own a 2.4. There's plenty of other guys around here though that should reply soon. Good luck.
Old 05-07-2005, 11:05 PM
justin0717 justin0717 is offline
A fuel pump would stop working when it got hot no matter what. It wouldnt matter what gear your in. So yes it does sound like the TCC to me. In your car its either the 2.5 or 2.3 right? Well i have a 2.4 and its simple. You need to remove the air intake tube, and right there you'll see a connector right on the bellhousing. Thats the one your looking for.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 05-09-2005, 06:09 PM
Re: Re: Torque converter
OK....next stupid question....actually 2 stupid questions.
1) What the heck does the Bell housing look like
2) What does the TCC look like?
Old 05-09-2005, 06:53 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
The bell housing is part of the transmission case. It's called a bell housing because if you stand the transmission on end that's exactly what the transmission would like-a bell, more so on an actual transmission than on an a transaxle like on our cars. It is the part of the case that bolts to the engine and it houses the/protects the torque converter or clutch in the case of manuals. You can't see the lock up clutch without removing the transaxle.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 05-09-2005, 07:03 PM
All I am looking for is the solenoid wire.....I was told that if I disconnect that, the stalling would stop and I could drive it to a garage.....as is I can't get to far. I was told that it is just a little plug with 4 or 5 wires on it, and it can just be unplugged.
Old 05-10-2005, 03:22 AM
Knifeblade Knifeblade is offline
http://www.autozone.com/servlet/UiBr...3d800e5c0e.jsp
Dunno how much this will help ya out, but it shows the main harness and the plug ins, with some possible idea of which to unplug.
Old 05-10-2005, 03:25 AM
also see GTP's response to bigess's thread farther down the forum page, it seems the TCC is on top of the tranny,
