Old 05-06-2005, 05:58 PM
crx-treme crx-treme is offline
It Starts! but trouble
so yeah my b16 started today after wrestling with the header/ac lines/ ac fan (decided to ditch the ac for now) throwing codes for knock sensor, intake air control and engine coolant sensor. the intake is not a problem i dont have anything hooked up yet.... coolant sensor i think is in the back of the block but im not positive if its the two wire plug or single wire plug...they are both plugged in. the knock sensor is plugged in dunno what to do about that.... any suggestions would be great
Old 05-06-2005, 08:03 PM
Scott82 Scott82 is offline
Re: It Starts!
Are you using a ecu jumper harness or did you repin your harness? The coolant sensor is the 2 wire sensor i am pretty sure, the 1 wire is prolly some kinda of oil pressure sensor but not sure, havn't fooled with that motor any but i have done that obd0 to obd1 wiring for a soch vtec. I didn't have a knock sensor on my motor so i am not sure about that either, someone here will though. But congrats on getting it started, it's a pretty good feeling when ya here fire up for the first time!!!! Good luck with working out the kinks, the hard parts over, and hopefully the rest will be a breeze.
Old 05-07-2005, 02:27 AM
i used hasport vtec harness, 2 wires replaced existing wires so i soldered them, other two were pins to the ecu plugs.....yeah it was great to here it fire up!!! thanks
Old 05-07-2005, 04:49 PM
ok my intake code is gone, but still have knock sensor and engine coolant temp sensor..... i rechecked wiring, everything seems to be connected. i switched the ect wires around, didnt do anything everything is soldered in so i dont know what to do. is there a way of checking the wiring such as with a voltmeter before i start rewiring everything?
Old 05-07-2005, 05:27 PM
Re: It Starts!
ok sorry had my codes mixed up its throwing 6 and 14, ect and air intake control. some one please tell me what to do ive checked the wiring 4 or 5 times!!!!
