Old 05-06-2005, 03:34 PM
ATMDC's Avatar
ATMDC ATMDC is offline
wheel wells and side moldings
sorry i keep askin questions, but i got 2 more, when taking off honda side moldings, whats the best method, i am going to refinish them and put them back on. and when taking the black plastic out of the inside of the wheel well, how do you do it, do you just break off those little plastic screw looking things and then replace them when your done?
Old 05-06-2005, 03:50 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: wheel wells and side moldings
Not sure about the side moldings, but I know those little plastic screws usually fall to crap when removing them... meaning, when you pull them out they really don't work anymore. I tried going to local parts store but the domestic ones don't really fit right... I'm using zip ties stealth like or no fender guards in some spots.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-06-2005, 04:02 PM
ATMDC's Avatar
oh ok thanks, thats what i thought
Old 05-06-2005, 04:05 PM
stickershop's Avatar
stickershop stickershop is offline
I really hate that Honda chose to use plastic screws for the wheel well liners. And Honda wants a small fortune for replacement plastic screws. Next time I have to take these off, I'm just going to weld nuts onto the backs of the tabs on the fenders and bolt them on with some plastic/rubber washers under the bolts. Problem solved...forever!
StickerShop.ca - got stickers?
High Quality Custom Vinyl Graphics, Signs, and Banners :thumbup:
Proud owner of two 1991½ Honda CRX Si Special Edition's (sequential VINs too!)
Old 05-06-2005, 04:20 PM
ATMDC's Avatar
lol, t a bad idea. anyone know about the side moldings?
Old 05-06-2005, 06:37 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
the side moldings have clips that break easily if you pull the from outside the car.
if you look inside the fender, you can pop the clips out there. same thing inside the door. take off the door panel and pop them out. the one on the rear quarter panel is tough to get to, you gotta take the whole interior panel out to get to them
or you could just break the clips while popping the off from the outside. but the door molding will bend when you do that
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
