| Let's get Technical! Discussion for hardcore in-depth motor heads! |
Cant keep caliper sliders from freezing
Long story short, I had my rear brakes apart on my 95 'Teg several times over the last few months (reason why not important). Each time, the caliper sliders were frozen, or extremely sluggish and took a good bit of effort to free them, with the caliper removed. Each time I used a good quality grease to re-assemble, either Sta-Lube or Permatex synthetic products. This past time, the sliders locked up again in less than two weeks!
The only culprit I can thing of is the fact that Im putting too much grease on the assembly and its preventing any movement of the slider. I am loading the slider and hole up with grease, to the point where I really have to FORCE the slider in the hole. Maybe too much grease is preventing movement and the heat generated by the brakes is gumming everything up, even in such a short period of time. Could that be the problem or am I out of my tree? How much grease do these things truly need to keep them free |
Re: Cant keep caliper sliders from freezing
you dont need alot of grease, just enough. use silicon grease
It's the grease. If you have trouble pushing it back in then it's way to much. Less grease should do the problem.....
