Old 05-06-2005, 01:24 PM
ewack ewack is offline
high pitched squeaking while driving
When I drive at speeds somewhere between 20 miles an hour and around 40 miles an hour my front right (i think that's where isn't coming from) makes a really high pitched noise. It's not constant though, it's like it happens when the wheel rotates to the same position. So the noise happens more frequently the fast i go.
Also my "low trac" light comes on when it shouldn't, it never stays on, it's just on and off alot more often then it used to. The light started doing that a short time before the noise started.
Would it possibly be the rotor being warped or bad? Or maybe I need new brake pads? (I have 51K on it, it's a 99 gls) Wheel bearing possibly? Any help is appreciated and if you can give me prices that would be a bonus. I was thinking about getting new slot and drilled rotors for it with new pads and then painting the calipers...maybe this would fix the problem?
Thanks
- E
Old 05-07-2005, 01:06 PM
mgs2006 mgs2006 is offline
Re: high pitched squeaking while driving
i just got four new pads and rotors from the dealer, it ran 480 dollars total with labor...hope that helps you somewhat..
Old 05-08-2005, 08:31 PM
Oh, and the noise is only when i'm moving. It quits making noise when i'm braking.
- E
Old 05-08-2005, 08:32 PM
Thanks, that gives me an area.
- E
Old 05-09-2005, 11:34 AM
biv343 biv343 is offline
I would guess wheel bearing for the squeaky noise sound, and hub/speed sensor assembly for the Trac Off light issue.
