Old 05-06-2005, 12:13 PM
MrSandman's Avatar
MrSandman MrSandman is offline
Replacing Driver Side Mirror
Has anybody in here ever replaced their side mirror on there Grand Prix? I have a 99 GTP, and I need to replace the drivers side mirror. I would take it to a body shop, but if I can do it myself it would save me some $$$.
Old 05-06-2005, 02:15 PM
ericvrose ericvrose is offline
Pull the door panel. Should be obvious after that. 3 bolts sticking through, I think, with nuts on them.
Old 05-06-2005, 02:43 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Replacing Driver Side Mirror
Send me a PM with your email address. I'll send you a PDF file with everything you need, even have to replace just the mirror.
Old 05-06-2005, 03:05 PM
MrSandman's Avatar
Thanks for the help
I appreciate the help.
Old 05-06-2005, 04:52 PM
Re: Thanks for the help
Glad we can help.
Old 05-08-2005, 11:00 AM
SUERED SUERED is offline
Yeah,
...add to above response--
That is what I did for the sister-in-laws '95. The problem was matching the paint color (for '95)---assuming you mean replacing the whole assembly. I do not believe you can do less than that from studying the old mirror. The wiring (if powered?) is a simple disconnect harness inside the door. If you have played mechanic before---opening a door panel is not a big deal if you have patience and keep track of what you are doing so as to reverse the procedure in reassembly.
Good luck.
Old 08-28-2005, 09:11 AM
stndmnky stndmnky is offline
i recently broke a pontiac mirror as well... is there any guideance on fixin it y'all could help me with?
